Hi all,
I having a few issues with my Jenvey Throttle Bodies (2 twin bodies same as MT196 SBD kit) and MBE 956 ECU.
I am struggling to find much information, I have all the throttle bodies balanced and TPS set perfect (Confirmed in Easimap).
My first issue is the Coolant temp sensor reads 90 degrees with connector disconnected and 130 degrees when connected and I cannot find how to calibrate this?
My second issue is that the base map i have is a TP208 base map and is way off and fueling is way way out (8-9 AFR on idle) and smokes, stinks, bogs down and uses fuel like no tomorrow. I cannot seem to find the suitable MT196 base map anywhere?
Any help would be greatly appreciated.
Many thanks and best regards,
Nick
Nick
