X30XE tuning parts, 265-275HP gain!
5.7K views 17 replies 5 participants last post by  KadettE V6 Noob
#1 · (Edited)
ALL PARTS SOLD!!!!! Ive got these parts from my old X30XE, thats gonna get your power up from 211HP to around 265-275HP / 320NM.
SOLD!!!!!Semi ported heads left and right, bigger exhaust ports, intake opened up a bit, and smoothed out the edges. New valve seals, renewed lifters. Shimmed 0,6mm for higher comp. rate. 15HP gain 250ÂŁ SOLD!!!!
SOLD!!! 272 degree cams, reprofiled 12HP gain SOLD!!!
SOLD!!! tubular manifolds, made in ordinary steel, special made with extra long 1.8" tubes connecting into 2" for each manifold, and into a 2.5" pipe. 24HP gain, made only for power, not for show. 200ÂŁ SOLD!!!
SOLD!!! Also have 6 x H-profile rods for the X30XE/Z32SE, good as new, 4000km tops. With ARP 2000 bolts. 300ÂŁ SOLD!!!!
SOLD!!!!! Complete X30XE intake system, 72mm AirMassMeter, C25XE wiring harness with C25XE ECU, remapped to this configuration. 170ÂŁ
No picture on this, but I guess everone know how it looks. :) SOLD!!!!!
Im from Denmark, so all parts are shipped from here also. Can ship worldwide, but please check for customs when getting packages shipped to your Country.
ALL PARTS SOLD!!!!!
#12 ·
Also have a X30XE lump, pistons and rods out, but available.One piston broken, cylinder bores intact. Crankshaft mounted and intact, new bearings, new gaskets for oilpump and flywheel side. Can be shipped on pallet, but surely a bit expensive. ;).. can be included in the deal if bying the whole bunch. Actually theres nearly a whole engine, just need a new piston, new big end bearings, and the timing belt kit. New water pump also. Well almost new, have run about 4000km.
