**X16XE Engine Parts**
1 reading
761 views 15 replies 6 participants last post by  Fow16v
#1 ·
All parts are from an X16XE and in full working order when removed:
Complete un-cut engine loom £50
Ecu £SOLD
Inlet manifold (with fuel rail, Pressure reg and injectors £15
Dispak unit £25
Starter motor £10
x16xe VGC Bottom end (complete with sump, oilpump ect) £40 collected - Ideal upgrade for x14xe
PAS Pump (like new) £20
Throttle body £20
VGC gearbox (f15cr) £50
Any sensors that you may need just ask. Postage available
PM or email: k11ova@freeuk.com
#7 ·
It should do mate as they are both small block engines arnt they.
I would think if you got the clutch all should be fine aslong as the flywheels are the same (ie pot/flat), post a thread in mech or electrical or do a search
#13 ·
OK thanks mate.... I have already bought 2 already, one was from a C16XE, the other a C16XEL with round ports, so just need one from a X16XE which should be the same as the X14XE and have oval ports between the top and bottom manifolds.
#15 ·
I've got a '99 Astra 1.6 16V Sport, do you know if this engine is the same (I'm afraid all I can remember is that it ends in 16XEL) and if so can you please let me know if the dispack you have is in full working order with no faults? Thanks and regards.
