Transfer box locking kits
28K views 51 replies 26 participants last post by  CB GTE
#1 · (Edited)
Title
Transfer box locking kits​
Description
Lock your own transfer box with this simple and cheap solution.
The biggest problem with the transfer box is the clutch pack becomes worn and slips, the debris in the unchanged oil will drastically affect the life of the epicyclic gear system until eventually it will destroy itself, if however it continues to work and the oil is changed once the clutch is so far worn it allows the clutch pressure piston to push past its seal allowing PAS oil to fill the box and pour out of the breather hose.
The locked methods i have seen else where just fit an extra clutch plate or two, this is all well and good but once any slippage begins to occur the slip WILL get worse and worse as there is no moving pressure piston to take up the wear. My option WILL NOT ever begin to slip, WILL not ever cause debris in the oil.
Each locking ring kit consists of 5 laser profiled clutch replacement gears and a cd rom with full instructions on how to fit them also on the cd is the Vauxhall 4x4 manual in pdf format.
Each kit is ÂŁ75 with free postage.
Contact me via PM or E mail: Mikeyhgsi@hotmail.com, Paypal is accepted.
As featured in Total Vauxhall last month!!
Any questions please ask i'll be happy to help.
Mike​
Declaration
  • I the seller have read and understood the Classified forum rules and understand that buying and selling on MIGWeb is done at my own risk and that MIG Performance Vauxhalls can in no way be held responsible for issues arising from using this service.
#7 ·
Cheers people.
The worst part is actually taking the box out, if its a task you can do then allow a day to do this but wou will need to change the PAS pipes so as to bypass the Acc block, and disconnect the 4wd ecu.
really need one of these can you quote me on a price for you to send a set to Perth Western Australia 6057
Hi, yes i can do this, i have sent them to aus before if i remember correctly it wasnt too expensive.
Send me an Email with the address please.
Stupid question,
If you fit a locking kit to the transfer box, can you then convert to rear wheel drive ?
NO.
The box has a Viscous coupling inside it, if you were to lock this as well, then come up with a blanking plate for the two front wheel drive shafts it could be done but i wouldn't advise it.
Buy a carlton GSI or a manta would be much easier
#6 ·
Stupid question,
#8 ·
BTTT
#9 ·
bump
#10 ·
more available at the moment
Mike
#11 ·
Just had some more Fabricated if anyones interested.
I have had these on Ebay for a while at ÂŁ115, but still only ÂŁ100 to any Mig member
Look out for the Total Vauxhall transfer box feature coming soon!
Mike
#18 ·
Hi Alan
Your PM box is full.
Mike
#14 ·
I really want this kit but im just scared about the abs issues i.e braking in wet/snow.
do you have lots left?
thanks
#17 ·
Kits are still available.
Please PM me for interest as I often forget to check the thread!!!
PM's sent to the above.
#20 ·
Some more kits in stock at present!
#22 ·
yes 5 gears which lock the annulus to the casing and replace all the clutch plates and the spacer ring.
Mike
#23 ·
so these rings replace the clutch plates?
Ive never had a transfer box appart, ill have to investigate!
#24 ·
Yes they do
BTTT
#25 ·
Hello mike...
I'm really interested in buy one kit for a project I'm building. Please tell me one think. With this kit we don't need any oil tube, Am I Wright??
Can you send it to Portugal???
Sorry about my English...
Thanks and Best Regards
#26 ·
Hi
Yes you are correct, no oil pipe required.
Yes I can send to Portugal too ;)
Mike
#27 ·
Hey mike, meant to say to ya i finally got round to fitting that last box you sent me, its awesome to get it back to 4x4...
Highly recommend one of these kits to anyone
And me and a frirnd had the box off and on in a day amd we aint overly mechanical!!!!
