Oil Pressure Relief Valve
7.8K views 26 replies 6 participants last post by  cwaigy
#1 ·
A while ago I had a problem on my car whereby the oil pressure on my Calibra (X20XEV engine) wouldn't kick in without blipping the throttle. I took it to a garage and they cleaned the oil pressure relief valve and it seemed to solve the problem.
However that was some time ago and it's come back again. I have to blip the throttle again to get the oil pressure to kick in. Once the pressure has kicked in again its fine until next time the engine is started. It is running at about 1 bar though at warm idle whereas before I'm sure it used to run at 2 bar which is a bit concerning but could be related.
Does this sound like the same problem again or could it be the oil pump itself? If its the relief valve would there be any benefit in getting the valve replaced rather than having it cleaned again as I'd rather this didn't keep happening?
Craig
#10 ·
westy1 said:
sorry can't help you there my engine in a westfield and dont use power steering pump .therefore not a problem. :)
Blimey, I bet that thing goes like stink with a 2.0 16v weighing what it does. The Westfield factory is just up the road from where I work in Kingswinford, West Midlands. Probably the places only claim to fame.
Craig
#12 ·
Well the cars in the Vauxhall garage being serviced and the mechanic reckons it's a big job to replace the relief valve and the air con pump, etc will have to come off. And even then theres no guarantee that it will be the relief valve, it could be the oil pump or some other problem so if the relief valve doesn't fix it then I'll have gone to the expense of getting that sorted and find out its something else I need to pay for.
Does it definitely sound like the relief valve? I start the car after leaving it standing, I get no oil pressure. I blip the throttle for a few seconds and then suddenly the oil pressure kicks in.
I got a figure of up to ÂŁ500 assuming he has to test every possible cause of the pressure loss at startup so I'd rather get him to try fixing the most probable cause first.
Craig
#13 ·
Oh, forgot to add. The mechanic said when he removed the oil filter after draining the oil from the engine nothing more came out when he'd expect more oil to come out, so not sure if that helps anyone make a diagnosis?
Craig
#15 · (Edited)
I'll learn one day. They've had the relief valve out and apparantly it's fine and the springs fine too, etc so looks like something a bit more serious.
There was talk of removing the sump which sounds expensive, although I'll have to book it back in for that.
Things that have been suggested include the Oil Strainer or the Oil Pump.
Craig
#16 ·
Sorry to keep posting but just wondered if anyone had any input as to the cause of my oil pressure problems as I'm not entirely convinced that the relief valve can be ruled out.
Just to recap, when I start the car after it's been standing for a while I get no oil pressure whatsoever and I can hear the engine rattling. If I blip the throttle to around 2000rpm or so for a few seconds then the oil pressure will kick in and I'll get normal pressure for the duration the engine is running and can drive around as normal with the pressure behaving exactly as it should. Once I stop the engine and leave standing for a short period the same thing happens again when starting.
It seems that once the oil is moving around the engine things are fine, but the problem is getting it moving requires the throttle to be blipped. Now although I'm not mechanically minded I'd have thought that if it was the pump then I'd still have problems even after blipping the throttle.
Any advice?
Craig
#17 ·
if you take the oil filter off, and the oil cooler sandwhich plate (if you have one) just off centre theres a ball and spring type non return valve. worth a look as its free.
the only other thing i can think of is blocked oil pickup pipe or failed pickup pipe seal, as vauxhall said.
other causes of low oil pressure are worn big end bearings, but as you say, its not so much low oil pressure, just some kind of fault of building up pressure
#18 ·
Cheers for that. I've just spoke to the mechanic and as they are doing a service I asked him to check the ball and spring valve you've described but he said that theres no oil cooler sandwich plate so he couldn't check the valve, although from reading your post it seems you just have to remove the sandwich plate to get at the valve rather than the valve being a part of the plate itself, although I might be reading it wrong!
Craig
#20 ·
Okay I picked the car up yesterday and the mechanic said when he put everything back together the oil pressure started working fine when starting the engine.
I verified this when I picked up the car, although it was difficult to tell as it's normally fine if you try starting within half an hour of stopping the engine, its when you give the oil chance to drain into the sump that it did it before and I'm not sure how long Vauxhall had it standing for.
So, this morning I start the engine and I get oil pressure fairly quickly, but the only confusing thing is, the engine blipped it's own throttle before the oil pressure kicked in this morning without me going near the accelerator which I've never seen it do before. Can they program the ECU to do that? If so then I'm a bit concerned that instead of getting to the bottom of the problem they've just set the ECU to blip the throttle on startup as a workaround.
Craig
#21 ·
problem still sounded like oil relief valve to me.
mechanic sounds a bit dozy if he did not know about filter ball bearing.
which makes me think did he really check relief valve in the first place.
some mechanic,s [not saying this one] will hang the job out to get more money out you.hence its always good to do it yourself if you can.
regards pete
#22 ·
I've been convinced it's the relief valve from the start but it's difficult to argue with someone who "supposedly" knows more than you and is telling you otherwise.
If I still get problems with it then I'll order a Nylon relief valve kit from SBD and either attempt to fit it myself, or find a more respectable garage or someone who's done it before on a Cally who could give me a hand.
Craig
#24 · (Edited)
I've got a feeling I've been conned by VX but I need some proof. They claim they've cleaned the relief valve but they did it too quick considering I've got air con and how big a job it sounds.
I've got it back and the pressure is kicking in automatically, but the only reason it's doing that is because the car is revving itself to 2000rpm for a few seconds (sometimes longer) when I start the engine.
It never used to do that so my suspicion is that instead of bothering to look at the relief valve VX have just set my car to rev itself for a few seconds which is enough to get the oil pressure to kick in. To me that's hiding the problem rather than fixing it.
So if I can stop the car revving itself to 2000rpm (sometimes only for a few seconds, sometimes for a minute) which I don't think it should be doin, then I reckon that my original oil pressure problem will magically return.
So how can I stop the car revving itself to 2000rpm by itself? It's a X20XEV.
Craig
