21 - 29 of 29 Posts
Discussion starter · #23 ·
ok, I've downloaded parts of EPC v2.4 with some Calibra pictures it seems (none of them look different to EPC v2.1). But it has more break point info in there.
I also found a page from Calibra workshop manuale detailing the engine changes and it shows the difference of upto MY93 and > MY93, see below (sorry about the large pic, it was the only way you I could get it so you can read the text)
I took a picture of my C20LET lump I bought with all the timing belts on etc, see below
So it seems I have a > MY93 engine. Its strange however that some of the parts I have taken off lists as early engines parts on EPC :(
I have a mungral (sp) engine too, its a late 93 20XE with the later belt design and DIS. However it has the early alternator V-belt and seperate V-belt for power steering pump. Also the later XEs have blue injectors with a 3 Bar pressure reg, my engine has cream with 2.5 bar (like earlyer XEs).
But in the end, who cares :rolleyes:
Discussion starter · #25 ·
Year my 1993 C20XE has blue injectors too (Motronic 2.8 with DIS unit). But my (now presummed) 1993 C20LET has yellow injectors.
early engines are much nicer to work on. i can do a cambelt change in about 15 minutes. later engines you have to take the engine mount off. it wouldnt surprise me if someone retro fitted early belt setup to a late engine.
The later XE's were ment to have Blue injectors, mine just has Cream ones.
Oddball > Why do you need to remove the engine mount?? I don't see why you have to.
would be true if I wasn't running a V-belt from the early model. But I am so there :p
21 - 29 of 29 Posts
