engine block's
477 views 3 replies 3 participants last post by  steveboyslim
#1 ·
I quess that it's possible to convert a c20xe block to a let block, if so what's involved.
#4 ·
1/2 inch BSP drilled and tapped in the same place as the original block, remove the oil gallery by the alternator mount on the block, where the turbo oil feed union is fitted, bore to required size.
I would use a Saab engine if you are worried about the car being blown away in the wind.
Steve
