Corsa Bolt- on Turbo Kits - 1.3 -1.4 -1.6
39K views 21 replies 11 participants last post by  muppetspor
#1 ·
Hello.
We are based in South Africa. We make a complete bolt on kit for the Opel / Vauxhall Corsa. We have had a kit on our test car (1.3) for the
Past 30 000 kilometres without any problems! the car at 0.4bar boost makes 92kw on the wheels!
The kit is comprehensive and comes with all parts and spares plus a interactive cd rom that covers complete instructions on how to install the kit to your car.
Two kits are available - a low boost version, no opening of the engine is needed with this version, the car runs standard compression.
And a high boost version, with this version new low compression pistons are provided. Higher boost can be run.. Around 1 bar as opposed to 0.4-0.5.
The kit comes in a sectioned cardboard box that is partitioned with the correct parts for each individual section of the manual! the kits comprise of the following.
Low boost: 0.4 bar boost ÂŁ2250 +plus shipping
Mitsubishi TD04 turbo
Exhaust manifold
Boost pipes – stainless steel or mild steel (your choice)
Rubber connector hoses
Intercooler
Higher pressure fuel regulator
Stainless steel Exhaust (complete)
Stainless steel Down pipe
All clamps and fittings
Blow off valve - (atmospheric)
CD Rom - Instructions
Manual - Instructions
High boost: 1.0 bar boost ÂŁ2750 +plus shipping
Exhaust manifold
Intercooler
Low compression pistons
Complete Gasket set
Engine rings
Uni chip computer (pre configured)
Uni chip Boost add on
Special harness for uni chip
Extra injector (350cc Bosch)
If you could pass this info on to your club that would be great. Orders can be placed via email.
Many thanks
Marc Hebert
marc@darkwater.co.za
#9 ·
John said:
Iirc the corsa in SA is the Nova?
And converting KW to BHP: 1KW=1.34BHP
So:
94KW=125.96BHP
160KW=214.4BHP.
I'll believe the first one, but sceptical about the second.
Just as an fyi Velos are currently working on a 300bhp turbo conversion for the 1.6 corsa. the price will prob be way above these just letting you know that 200+ is probably feasible.
#10 ·
engines
The kits have been developed for the 8V so far, we can do a 16v if there is a request.
Price is negotiable as well, if it is too high, be reasonable and tell me what you think is better.
Power figures for the low boost are confirmed with a Dyno. The high boost is an estimate, have not dyno'd yet, will confirm.
Marc
