C20xe breather pipes - where to what?? help needed
3 reading
1.5K views 2 replies 3 participants last post by  Davey j
#1 ·
Alright,
I'm looking for advice on the breather pipes for a c20xe.
What ones go where? Any good guides?
I've got 2 to fit onto the inlet from the bottom underneath throttle body, what pipes go onto there?
Fuel breather pipe onto inlet somewhere?
Also on fuel rail any other pipes?
As you can read i'm pretty clueless with all this, Any help much appreciated.
#2 ·
the one under neath about one inch diameter goes on the idle control valve then from the other side of the idle control valve up to your power cap or eco teck pipe.
there is a valve called a purge valve which should be on a bracket where the bolts go through passanger side of the inlet a little vac pipe goes from the throttle body (1 of the 2 smaller vac pipes on the front) to this valve the from this valve to one on the bulk head which goes the carbon canister.
there should be two fuel pipes in the engine bay, power the pump to see which it sqirts out of, connect the one that doesnt to the fuel rail were the fuel reg is the dome shape thing obviously the other pipe to the other side.
hope this helps
#3 ·
17mm head fuel pipe goes to the offside fuel rail near FPR and the 19mm head one goes nearside at dizzy end. Small diameter breather off throttle body to small cam cover stub and the larger one sits next to it, also off the throttle body.
