1.7cdti warm start problems
410 views 1 reply 2 participants last post by  dover mk3 astra
#1 ·
Hi all,
trying to get to the bottom of warm start problem, starts fine when cold..trawled the tinterweb and cant find an answer.
The only thing i can think of is the temp gauge in the car takes a long time to move ,15 min, could this be fooling the ecu thinking the engine is cold and causing over fueling or glowplug to still work when hot?
Anyone got a solution? i have seen water in wiring, egr, cam sensors, glowplugs, airlock, fuel pre heater, starter motor suggested but no one has ever said they cured the problem after replacing.
#2 ·
if the coolant gauge takes a while to move then would assume thermostat is/has failed.
could also be a vacuum pipe split enough that when its warm the gap is enough to cause a problem, or lose clip/split intercooler pipe etc..so check all pipe work 1st as could be as simple as that.
