Tabs,
looking at the engine from the front of the car you'll see the actuator rod is connected at the right hand side end to a little arm that is in the manifold, to check if it is siezed undo the right hand retaining nut and see if the arm will move anti-clockwise (mark where the left hand nut is as the tension on this bar is how the boost is adjusted), if it don't it might be siezed. The wastegate is simply a disk on the end of this little arm that opens and closes when the actuator tells it, when its open exhaust gases go around the turbo rather than drive the turbines, its quite common for the disk to come off and go down the exhaust (as mine did and smashed the fog light on my wifes astra as it came out). If there's no wastegate there will be no boost. easy to tell if the gates gone cos the arm will rest at 6 o'clock if it's there (turning clockwise) and will move to about 8 o'clock if the gates broken.
The wastegate is physically part of the manifold not the turbo, but the turbo needs it to operate properly and is a ÂŁ50 DIY job to fix. so don't panic if yours is fooked.
Lee.
