Hello,
does anybody know the dimension of the outlet of the z20leh turbo?
is it 60mm?
I'm looking to buy silicone hoses for it but am not sure what size to order. The outside diameter of the outlet (or pressure side) of the z20leh turbo.. is it 60mm? or is it 57 or63? - this hose should be a 90 deg elbow
i've been searching for a while but can't seem to find this info
p.s. i'm not looking for a complete kit, the rest of my intake is not stock
Thank you all
best off removing the hose, and measuring the outside diameter of the turbo pipe, with vernier caliper, to be certain. then you can get a snug fitting hose, that isnt gonna potentially leak, or blow off, under boost.
