I've got a nice alloy PAS tank I want to fit to the Calibra Turbo but it is about the size of an XE tank rather than LET. Does anyone know the capacity of either tank, I think the LET tank is bigger? Would it cause any problems running a smaller PAS header tank on an LET?
Tank is bigger with 4x4 (same size with either the LEt or XE), needs to be able to hold the fluid that is held in the accumulator.
If you fit a tank that is too small the fluuid could over flow, remember that you have to empty the accumulator to check the PAS level.
Is there any spare 'buffer' in the volume of PAS fluid i.e. could you run with the difference in volume between the two with 4x4 and be OK?
