i will be fitting alpha throttle boddies to my engine hopefully the last weekend of this month.
im ok with fitting the kit but just want to make sure i get it wired up corectly.
the instructions i have are for a vectra so need to know what the diffrences are between the loom compeared to my astra one.
on the vectra the below need to be connected to the multi-plug bulkhead wheres this plug on my astra?
tb loom - original loom muilti-plug.
tachometer-top righthand pin green wire
fuel pump-feedtop lefthand pin blue/red wire
ignition switched feed- second from top righthand pin black wire
coolant tempature sender-second from bottom lefthand pin blue wire
air conditioning-air con compressor red wire
will also be fitting at the same time
cams and verniers
exhaust 4-2-1 manifold and cat replacement pipe
lightened flywheel and new clutch arp flywheel bolts
evual lenght drive shaft
apr con rod bolts
+more
if anyones up for lending me a hand please let me know.
(realy need someone to take it for a spin once all fitted as im band from driveing)
will be doing it on 29/30/31 of this month and the first of next month if needed.
cams and verniers
apr con rod bolts
+more
