1 - 8 of 8 Posts
Have seen a pair of 4 pot willwoods with mounting plates for a cav gsi - will these fit me tub?
obviously i will need new pads but what are the chances of my Goodridge hoses mating up to the willwood calipers?
I have a set of dynalite on my nova, had to get custom hoses made up but the calipers were off a rally car so were odd.
Give monster breaking power too, just not when the pads are cold though
They won`t fit a Turbo as they have 5 stud hubs & the GSi` have 4 stud.
You could probably get the rigth discs pretty easily though or get the 4 stud one re-drilled to 5.
Its just the calipers i've seen for sale - I think due to the size difference in discs (turbos being a larger diameter) that i would have to get new brackets made up.
The Willwood calipers are probably designed to run wider diameter discs as well.
Discussion Starter · #7 ·
I've asked the seller what model of Willwood caliper it is - it will give me a chance to check the spec and cost new ;)
1 - 8 of 8 Posts
