why does the let motronic 2.7 need a speed reference from the abs system ?
if you can follow haynes manual wiring schematic> page 353, line 1122 goes to page 349, line 733 which is the speed signal from the abs to the electronic speedo. then it goes out from page 349, line 731 to page 345, line 344(4wd) and 371(mot 2.7) i can live with the 4x4 ecu needing it cus of the 16mph requirement but to the motronic i don't know why ???
it adjusts the fuelling and ignition maps according to speed i guess?
ie medium throttle, unchanging speed = cruising so lean off fuelling a bit?
does the speed sensor lower the boost in 1st and reverse for more control when pulling away?
or is that a differnt sensor all together?
it needs a road speed signal to initiate over run fuel cut off abnd to regulate the idle speed when moving to prevent stalling.
Its not a chainsaw it needs to know if its loaded or not.
is the speed sensor wire the blue with red tracer from ECU loom in the car?
am i right in thinking this should splice in with my digi dash speed sensor wire?
