That's what's on the old diesel engine, the new one has 240nm of torque so thought must have different gearbox?Mark T said:F17 I expect.
ChrisReay said:That's what's on the old diesel engine, the new one has 240nm of torque so thought must have different gearbox?
Specifications
Engine Z 17 DTH
No. of cylinders/ layout 4 in line
No. of valves 16
Capacity cm3 1686
Bore diameter mm 79.0
Stroke mm 86.0
Power output kW / rpm 74 / 4400
Torque Nm / rpm 240 / 2300
Compression 18.4
Exhaust emissions standard Euro 4
TIS said:The main changes to the Z 17 DTH engine, compared with the Z 17 DTL engine, at a glance:
Turbocharger with VNT technology
Denso Common Rail system
Denso high-pressure pump
EGR cooler
Engine timing
Twin-mass flywheel
Oil life monitoring
