as the title would suggest, where can I get a 1.9mm gasket for a x16xe, or will it have to be custom made. also, do I use normal gaskets either side (sandwich) also, and what would I torque it to? (im guessing more than standard).
cheers, mark
what set up you running to get 245 tigra?
The Tigras Engine specs:1.6 xe.SBD 967 ECU,green Bosch injectors, custom US J.E pistons+wisseco rings pistons,steel rods with ARP bolds,ported and polished head,uprated single valves springs,stock cams,balanced rods,crank,flywheel,SBD steel inner oil pump gear and teflon stiffer spring relieve valve setted up at 75 psi,T 28BB turbo custom intercooler,Mantzel inlet,courteney exsaust manifold,stainless steel pipes,samco colars,remote filter plate,oil cooler,custom water cooler,92 Celsium thermostat and valve ITG air filter.
cometic for gaskets if i were you, they will make a double thickness one if needs be, and are very helpfull/friendly to deal with
