1 - 7 of 7 Posts
I can't find it near the battery like i've been told. Did they ever put the mk4 ECUs in the drivers footwell like on the mk3s?
Here's a pic of the area near the battery, there are a bunch of wires around there so it looks like the ecu should be there but i can't find it! I wanna check the number on it to see if it's one of the dodgy ones.
Can someone do something like put a circle around the area where it should be?
Thanks a lot :beer:
Just out of shot there. Right hand side of battery with 2 terminals and connectors. Its a flat metal panel.
that make sense cos one of the plugs goes to the weird thing on top of the cam cover that i'm guessing is some new-fangled spark plug holder type thing.
so, it's not under the coolant header tank, and it's not under the battery tray.... wtf, where is it?!
Doh, i just re-read your post and you said 'so' not 'no'! so that's it then, wahey!
1 - 7 of 7 Posts
