will et 37 and 4/100 pcd wheels fit an astra mk 4 if not what pcd and et do i need
G gareth · Registered Joined Nov 30, 2001 · 309 Posts Discussion Starter · #1 · Feb 4, 2003 (Edited) Only show this user will et 37 and 4/100 pcd wheels fit an astra mk 4 if not what pcd and et do i need
D DaveVlcek · Registered Joined Feb 28, 2001 · 3,700 Posts #2 · Feb 4, 2003 Only show this user Is you Astra 5 stud or 4 stud?
G gareth · Registered Joined Nov 30, 2001 · 309 Posts Discussion Starter · #3 · Feb 4, 2003 Only show this user 4, the new wheels are 4/100 pcd
D DarrenH · Registered Joined Jan 14, 2001 · 30,330 Posts #4 · Feb 4, 2003 Only show this user 4x100 is the correct PCD for standard 4 stud vaux wheels the hole in the middle of the wheel should be on or around 56.5mm, but i expect you have those plastic spiggot rings.
G gareth · Registered Joined Nov 30, 2001 · 309 Posts Discussion Starter · #5 · Feb 4, 2003 Only show this user what about te et???
Scott G · Registered Joined May 20, 2001 · 11,720 Posts #6 · Feb 4, 2003 Only show this user Im guessing you meant et37, i cant see there being a huge problem with these but they will stick out a bit, and handling wont be so great. Ideally your looking for 42+ Depends how much its lowered if at all.
G gareth · Registered Joined Nov 30, 2001 · 309 Posts Discussion Starter · #7 · Feb 4, 2003 Only show this user have correted it now have only just read it back so et37 should be okay
D DarrenH · Registered Joined Jan 14, 2001 · 30,330 Posts #8 · Feb 4, 2003 Only show this user no 42 + i.e between 42 and 54 ET38 and 100pcd sounds like a VW wheel.
G gareth · Registered Joined Nov 30, 2001 · 309 Posts Discussion Starter · #9 · Feb 4, 2003 Only show this user i think the wheels came off a renault thanks for the info oh well guess i will have to keep looking
M Mark T · Registered Joined Dec 7, 2001 · 17,641 Posts #10 · Feb 4, 2003 Only show this user http://www.tyresave.co.uk/fitment.html
