Hi,
I'm looking for a clutch for my 1.4 Tigra does anyone know what size it is?
Is the same clutch used on any other vauxhall (other than the 1.4 16v corsa for obvious reasons - as i know it is the same)?
Thanks
Craig
Discussion Starter · #2 ·
While i'm on the topic,
Which gearbox do i have in the Tigra?
believe its 210mm and either an F13 or F15 gearbox- both 'boxes are Close Ratio IIRC?
clutch is actually 206mm apparently, just looked it up
I just looked it it and its a 190mm in a Tigra the Corsa 1.4 16v runs a 200mm clutch
Here's the cars it shares with
MK 2 Astra / Belmont 1.2/1.3 86-89
MK 3 Astra 1.4 91-98
MK 3 Cavalier 1.4 88-95
Nova 1.2 87-93
Nova 1.3 87-93
Nova 1.4 87-93
Found the info by using the product codes from Standard EBC Clutches from this site
http://www.motorsportworld.co.uk/manranges.asp?code=29
Craig
