1 - 8 of 8 Posts
Right this is the problem.
for the last couple of days when the car has been idling even for just a couple of seconds or after it is first started there is a gurgling/noise of moving water from behind the dash near the heater matrix.
THe car doesn't lose water/expansion tank upto mark, no leaks, footwells dry etc
Is this an air lock? If so why has it only just started to happen (not been drained for a while). Any ideas how to fix?
cheers
ok i got a prob as well, my water disapears after about 100 miles, head aint blown, just repaired a split hose, i get this water sound comin from under bonnet after being run then ticking over any advice on what it could be?
My astra done that - its like a sloshing behind the radio in the centre of the dash - Mine lost coolent all the time - found a leaky hose and thought i had fixed it
450 miles from home it goes bang - Head gasket failure
My V6 was doing the same thing when i bought it, it was loosing coolant and sucking air from a knackered water pump. New pump problem was solved.
1 - 8 of 8 Posts
