VDR600 Radio Stuck on SAFE 7, can't enter code.
11K views 3 replies 3 participants last post by  Astra zelenka
#1 ·
Hi,
My Vectra radio is just displaying SAFE 7 and I can't get to enter the code. I have tried the usual, radio off, ign. on, hold AS and turn radio on. Keep holding AS, but it never changes off of SAFE 7.
Has someone tried to enter the wrong code to many times and locked it out?
Is there anything I can do to get to enter the code?
Thanks.
#2 ·
yep the code has been entered wrong 3 times (safe 7 means 7 tries left) everytime you enter a wrong code, the time between entering the code increases. to get the radio to allow you to re enter the code, you will need to switch it off and ignition off, switch the ignition on, press as and switch the radio on at the same time, and then wait for safe 7 to go off and the 4 ---- to appear. im unsure on the time to wait but you cant speed it up.
