Vauxhall Radio Codes Available From 9 am to 11 pm daily
do not forget there is Discount Button on the site which gives you a 10% promo code.
Code Entry Instructions For Most Vauxhall CD & Cassette Players.
Make sure the CD or Cassette Player is switched off before you begin.
Switch on the ignition, you do not need to start the car or van.
Press and hold the AS button whilst switching the unit on.
The display will now show SAFE followed by 10 - - - -
you can now enter the Radio Code.
Press the button 1 repeatedly for the first digit of your radio code
Press the button 2 repeatedly for the second digit of your radio code
Press the button 3 repeatedly for the third digit of your radio code
Press the button 4 repeatedly for the fourth digit of your radio code
If the correct radio code number is displayed you will then need to
press and hold the AS button until the CD or Cassette player beeps.
The unit should now be working. If the display returns to safe or
9 - - - - this means the code is not being accepted, please check you
have the correct code, do not keep trying the incorrect code as you
only have 10 attempts before the unit locks up and has to be reset
using decoding hardware.
Any questions feel free to ask.. Hope this helps :thumb:
