21 - 30 of 30 Posts
Discussion Starter #21
Engine loom finished. Not much with only running carbs. Alternator, Starter, Oil Pressure Sender, Oil Pressure Light, Oil Temperature, Water Temperature, Coil & Crank.
22428
22429
22430
Discussion Starter #22
Haven’t had any luck with starter motors. The first starter motor that came on the engine, was worn out and lazy and the original. Had another 2 starters in my spares that I’d got from my old rally car a few years ago and they were also both not working. New one ordered which should be here tomorrow afternoon so we can finally crank the engine over.
Discussion Starter #23
New starter motor on and it cranked up no bother. Engine & Spot light loom are finished. Just Front lights & rear lights to start and a interior loom to start which has Fuel pump, Intercom, Fuel Sender, Interior light and Map light.
Bought a 9” Comex suction fan to replace the standard fan. Much neater and plenty of room compared to the old fan.
22433
22434
22435
Discussion Starter #24
Heated screen is now in
22448
Lighting loom is all finished as well, H4 LED Conversion and all other bulbs around the car are LED.
22449
22450
22451
Discussion Starter #27
Compomotive TH Wheels all stickered up
22480
Engine breather system nearly done, just waiting on a breather filter.
22481
Gold reflective heat tape put on the exhaust tunnel
22482
New F20 machined hubs with SKF bearings & new flanges
22483
Few more jobs and it should be on the road
Discussion Starter #30
Good update from this past week. Car went up to Angus Lawrie Motorsport for a few jobs and collected it today.
Quaife Gear linkage
Kevlar Sill Guards
Full suspension geometry
Mudflaps
22512
22513
22514
22515
22516
22517
22519
Looks a totally different car now with the sill guards & mudflaps. Gear linkage is so precise and the throw between gears in minimal, whole car will take some time to get used to.
Take the car down to Tony Law exhausts on Tuesday for a custom system then ready for a MOT next Saturday.
21 - 30 of 30 Posts
