1 - 20 of 27 Posts
Never been on here before but I thought I would share my project that I’ve been on with for about a year now. Full project from start is on PNG but will post a few pics from start to now.
Here’s some photos from roundabout this time last year when I got the cage & fabrication work done. Luckily it was already a rally car so had all strengthening plates etc on. Got rid of the bolt in cage and put a Hockly Motorsport weld in cage instead.
22345
22346
22347
22348
22349
Start of November 2019 I got it in the bodyshop for some paint. Gone for a Aston Martin colour inside, something a bit different & Glacier White outside.
22355
22356
22357
22358
22359
22360
22361
Engine dropped in at the start of February.
Engine Spec:
X14XE built by Bill Falconer
Omega Pistons & Rods
Lightened & Balanced Crank
Ligjtweight flywheel & AP Racing Clutch
Baffled & Gated Sump
Bills new development head
Standard GM cams that are re-grounded & profiled
Solid Lifters
Double Valve springs
Re-designed alternator pulley to cope with the higher revs
Oil breather coming off the top of the cam cover instead of to the right hand side
Twin 45 Weber’s
MBE ECU ignition only
180 Bhp
135 lt/lbs torque
22377
22378
22379
22380
22381
thats a great looking shell youve got there. most nova's are rot boxes, these days.
what rear calipers have you got there, they look like 2 pots ?
Yeah it is a very good shell, only had about 20 minutes worth of welding to do. The rears are just Astra GTE. Don’t need much more than that as it’s easy to over brake them in the rear
Discussion Starter #11
Fitted lockstops in the rack this week to protect any damage to the drive shafts. Bit of locktight around the edge of the washer and sealed it with sikaflex to stop it from working loose.
22394
Wednesday I got engine bay fire extinguisher system all installed.
22395
22396
22397
22398
22399
Discussion Starter #12
Auto electrician that is doing a full new loom for me sent some photos over of the dash all wired up
22400
22401
22402
Discussion Starter #13
Front Polycarbonate windows in on Friday, used Ford Focus & Ford KA window rubbers and they fit perfectly after trimming.
22403
22404
22405
22406
22407
Discussion Starter #14
Few photos of the Quaife F20 box that I got stripped down & a new Gripper diff put in.
22409
22410
22411
22412
Discussion Starter #16
Chucked a seat in tonight and got my position on the seat rails bang on. Got a rough idea of where I want my steering wheel at as I’m gonna be using a weld in quick release boss because I wouldn’t be able to get out of the car with a standard boss because of the cage and seats. Makes abit of a tidier job aswell
22416
22417
Discussion Starter #18
Dash is all finished so got the extinguisher nozzles & lines in today.
22419
22420
22421
22422
Discussion Starter #20
Just the plugs to wire into for the Engine Loom, Light Loom and Car loom. Easy to unclip everything if I ever want the dash or engine out.
22426
22427
1 - 20 of 27 Posts
