Hi All,
My engine has gone bang on a 2014 1.0 corsa.
my question is, if I change it for an identical 1.0 engine on eBay, will the ecu accept it or will programming etc be required?
Many thanks,
Ben
My bakkie have no oil pressure after replacing the oil pump don't know how to prime it or maybe same silicon in system soi want to know the position of oil pressure control valve to clean it
I have a problem with my astra g gsi z20let when idlig. It's an intermittent fault that results in the car nearly stalling on idle and then the service light comes on and stays on for the next 4 or 5 starts or until the engine gets a good long sustained burn such as a motorway drive.
Vauxhall...
Hi all
Recently bought a mk5 Astra Sri 2.0 turbo. It was advertised as needing new piston rings - the guy said he thought it was just the head gasket but after replacing that it was still not running right and he said he got a compression test and cylinder 3 was low.
The car did actually drive...
Hi all,
So bought a classic 98 Tigra with the X16XE engine, replaced head gasket on only 33,000 miles but that’s fine, all went well.
Fired up and ran like a dream for a few days, then it seemed to be idling very high. Took it to see what code it gave me and it was the PO505 Idle Air...
Hello all
Looking for a cylinder head kit (all gaskets, bolts etc) for my MK4 1.7dti van. Going to do the head gasket soon.
There are many on ebay, but I want a quality one. Any ideas? Are the ones on ebay any good?
I know Vauxhall will cast about £150 to £200 maybe, not sure
cheers
