Currently got my 2.5 x25xe stripped down and I have a 3.2 block I was going to put the heads onto but then I realised the 3.2 gaskets are
round as opposed to 50p shaped on the 2.5 ( I didn't even think the obvious here but not the issue )
I then realised that the pistons in the 3.2 are flat whereas the 2.5 has reliefs for the valves.
My question is will I need to get valves from a 3.2 to fit or will the 2.5 valves be okay without hitting the pistons?
Your help is appreciated as always.
