1 - 8 of 8 Posts
What causes a tyre to squeal? After adjusting the camber/castor on my corsa and having a full allignment my Continental Contacts are now squealing quite bad in hard corners. They NEVER used to squeal ever when I was running 2 degrees of neg camber?
I remember some old remoulds :( that I had used to squeal all the time!
Cheers :beer:
Camber, castor and toe all can cause tyres to squeal.
Get all of them checked.
No its still running some negative camber, just a bit less though to reduce inside edge tyre wear. All are correct as ive had a full allignment done by a very trustworthy lazer alligners. Its only when I corner VERY hard though, just embarrising that it makes so much noise : (. Whenever ive watched Tiff of TV booting cars a lot of the time their tyres squeal, just wondered why mine didnt and now they do?
The wrong tyre pressure can also cause tyres to squeal
1 - 8 of 8 Posts
