Admin/show reporter
Right a while back my TXB system decided to dump PAS fluid all over the road. After a quick inspection and seeing PAS fluid all over the TXB and the end of the gearbox I concluded that the TXB had blown it's ram seal and PAS fluid came out of the breather pipe (common fault).
I have just removed the entire kit from the calibra and found something out, the pressure relief valve directly behind the pressure bulb has blown (obviously where the PAS fluid came from).
So could my TXB be intact, is there any way of testing it. If it's ok I can sell it.
John.
