Can i have a picture of your oil returns on the block please, ideally if some one has done it to the XE Block :D Cheers in advance:D
im also interested in this, oil feed too if poss
oil feed is from the back of the block theres 2 hex screws right near the oil pressure sender as far as oil return take it straight to the sump
ok i got the oil feed, but i heard u have to tap into the block because the return needs to be above the oild level any more pics
