1 - 20 of 37 Posts
I have been offered a LET lump with ECU... but the loom is missing... F**k knows why ??? It's cheap, cos of this.
Now, is there anyway of making up a loom????
I can get a Cav GSi loom, will the plug on that loom fit the Turbo ECU ???
Does anyone have a Wiring Diagram, or could help me with the wiring ????
Or is it just a really bad idea... and i would need to buy a new loom ??????
cheers :beer:
How come ???? surely with a wiring diagram, it should be relatively straight forward ??? If i drop it in the GSi... it'll have all the XE sensors and stuff there already ?
Well, there appears to be a fair bit of a diffence between my XE and LET loom - there's also a vacuum attachment for the ECU.
If the LET is seriously cheap, you could enquire at Vaux or Autovaux?
Discussion Starter · #7 ·
Yer, the only thing missing is the gearbox, intercooler and loom !
Gearbox isn't a problem, can just put a f20 on... and hope it don't blow up too often lol
the intercooler, sure i can get a 2nd hand one... and just slap a bigger one on
just the loom i was worried about !
replied on Cavweb.
Don't look too difficult.
I would do it for a £100 engine.
crank and cam sensors look in different pin positions.
other than that the extra turbo sensor wires assuming you start with a M2.5 loom with oxygen sensor.
add wires for
inlet temp sensor
hot start valve
boost control
1st / reverse gear switches
Sounds like you will be missing lots of pipes but for £100...
Discussion Starter · #19 ·
well it's apparently supposed to be complete apart from the intercooler , transmission and loom.
So i would hope their all there... unless any of the air pipes are in the loom !! ??????
1 - 20 of 37 Posts
