1 - 10 of 10 Posts
Right then, ive seen a few threads about exhaust diameter in the past now what about length?
Does the length need to 'tuned' at all or will putting a significantly shorter item on be a problem?
Say it was half the length of standard, exiting elsewhere, any issues? On a well tuned LET BTW.
J
Majority vote is for least restriction possible. Seen a few that are simple short dump pipes (on rear engined cars).
And others like the Dahlback (?) Golf which exits before the rear wheel.
Discussion Starter · #9 ·
Back pressure issues with a turbo? ie as in not enough wont you get weeping seals?
Willing to be proven wrong, but I don't buy that one. The seal is in the housing, which is before the exit of the turbo. Can't see how back pressure (unless a LOT) would affect the seals, unless they were knackered anyway.
1 - 10 of 10 Posts
