1 - 18 of 18 Posts
For Sale,
12-14psi uprated Turbo Dynamics actuator for kkk16. as fitted standard to their hybrid turbo's. covered approx 15k miles but holds 14psi with no probs at all.
£40 inc P&P
Discussion Starter #2
BUMP^^
ideal for those running up to V-Max evo 3 or EDS phase 2
Up she goes ^
e-mail sent :)
Hi matey,
why would this benefit if running phase 2? cheers adam
Hi adam - its of use for those running P2 if they dont already have an uprated actuator. rated at 12-14 psi it allows for setting the correct boost levels without the amount of pre-load that you would have to have on a standard actuator.
Discussion Starter #8
Bump ^^
hmmm a question:
my hold 14/15psi now so is there any point aving ur's if it only holds up to 14psi?
Adam said:
hmmm a question:
For a standard one to hold 14/15psi it'll have been pre-loaded, which isn't a good thing. This one, apparently, will run 14/15 with the same preload as the standard one would hold 6.
afaik
so what about phase 3, would it run that??
havent got a chip yet but will get either ph2 or ph3 just seeing.....think ph 3 holds at around 17psi if i remember right?
Discussion Starter #14
Hi,
i would suggest that its not really ideal for Phase 3. I upgraded to run Phase 3.5 properly.
I will e-mail some pics this evening for you :)
so a deffinate yes no....will it hold ph2 nice and steady as i have a chip set that i have my eye on....does it come with the bracket and everything to mount it to a standard calibra turbo or what else do i have to buy and how hard is it to change?
Discussion Starter #18
provisionaly sold to the_fbi :beer:
cheers for the interest guys :)
1 - 18 of 18 Posts
