  1. sorry guys if this is in the wrong sub forum, what are the torque settings for a c20 let im usin 1.9 mm head gasket if that makes sense
2.0L 16V TORQUE WRENCH SETTINGS
Specifications subject to change without prior notice - issue date 2.2.07
MAIN CAP BOLTS- STD & H/D
GRAPHITE GREASE UNDER HEAD,OIL THREADS
STAGE 1---37 LB/FT 50NM
STAGE 2---40 DEG-50 DEG
BIG END BOLTS
STANDARD TYPE GM ROD BOLTS
STAGE 1---26 LB/FT(GRAPHITE GREASE UNDER HEAD,OIL THREADS)
STAGE 2---45 DEG-60 DEG
Heavy Duty Rods Bolts for Standard Rods (9mm x 1.25mm) 2.0L 8V/16V
RB1/RB1K---31 LB/FT with ARP assembly lubricant - See separate assembly sheet
Heavy Duty Rods Bolts for Steel Rods 2.0L 8V/16V
RB3/RB3K (FOR ROD143S) (3/8” UNF) ARP 2000 bolts - See separate assembly sheet - 45LB/FT with ARP assembly lubricant
RB4 (for ROD148S) (5/16” UNF) ARP 625+ (custom age) High Spec Bolts – 30 LB/FT with ARP assembly lubricant.
NOTE: - When assembling the bolts, as of 2002, the manufacturers recommend only using ARP assembly lubricant as supplied, under the heads and on the threads and torque up to. These are lower torque settings than would have been used with normal oil. We cannot be held responsible for rod bolt stretch when an uncalibrated torque wrench has been used.
OIL PUMP BOLTS
4 LB/FT 6 NM(242 LOCTITE)
CRANK BOLT
GRAPHITE GREASE UNDER HEAD & WASHER, OIL THREAD
STAGE 1---184 LB/FT 250 NM
CAM CAPS
15 LB/FT 20 NM
CAM PULLEY BOLT
STAGE 1---37 LB/FT 50 NM(242 LOCTITE)
CAM VERNIER PULLEY BOLTS
14 LB/FT
CAM BELT AUTO TENSIONER BOLT - XE/LN ONLY
15 LB/FT
IDLER PULLEY BOLTS
STAGE 1---18 LB/FT 25 NM(242 LOCTITE)
FRONT PULLEY TORX SCREWS
15 LB/FT 20 NM(242 LOCTITE)
SUMP BOLTS
242 LOCTITE
STEEL SUMP---4 LB/FT
ALLOY SUMP--11 LB/FT
DRY SUMP-----10 NM
FLYWHEEL BOLTS
242 LOCTITE
STAGE 1---48 LB/FT
STAGE 2---30 DEG-45 DEG
CYLINDER HEAD BOLTS for standard gaskets
GRAPHITE GREASE UNDER HEADS & WASHERS, OIL THREADS
SEE SEPARATE SHEET FOR TIGHTNING SEQUENCE
STAGE 1---18 LB/FT 25NM
STAGE 2---65 DEG
STAGE 3---65 DEG
STAGE 4---65 DEG
CYLINDER HEAD BOLTS for Cometic gaskets
IF COOLING MODS HAVE BEEN DONE THEN COMETIC GASKET MUST BE DIMPLED
SEE BELOW FOR TIGHTNING SEQUENCE
STAGE 1---25 LB/FT 34NM
STAGE 2---42 LB/FT 56NM
STAGE 3---59 LB/FT 79NM
STAGE 4---75 LB/FT 100NM
ARP HEAD STUD KIT PRE 93 ONLY
63LB/FT Only (Using ARP lube)
80 LB/FT Only (Not using ARP lube, e.g. Graphite grease)
2.0L head bolt sequence
this is off the sbd web site
BIG END BOLTS
OIL PUMP BOLTS
CRANK BOLT
CAM CAPS
15 LB/FT 20 NM
CAM PULLEY BOLT
14 LB/FT
15 LB/FT
IDLER PULLEY BOLTS
SUMP BOLTS
242 LOCTITE
DRY SUMP-----10 NM
FLYWHEEL BOLTS
242 LOCTITE
STAGE 1---48 LB/FT
STAGE 2---65 DEG
STAGE 3---65 DEG
STAGE 4---65 DEG
Do you torque to the same settings when using ARP bolts as if you were using standard bolts? (As per haynes) Thanks
ARP bolts need to be tightened, slackened, tightened, slackened then 3rd time tightened and left.
btw theres 2 dif torques for the heads.
ones something like 65nm or ftlb and 3 lots of 90 degrees
hi i have a problem i have a set of qed motorsport flywheel bolds,non arp but they are exactly the same as arp,can anyone tell me how much tourque please,and even the head studs are from qed and i don`t know the tourqe
