Originally, yes, that 1 1/2 wide garage was going to become 2 1/2 wide..
Then 'we' decided that if it slid out by a car's width, then it could still be a 1 1/2 garage, with an extra reception room, and second bathroom, meaning that the silly little cloakroom in the utility could be removed, making the utility bigger..
Of course, the public sewer under the proposed garage and current conservatory put paid to my inspection pit as well..
Builder can't beleive the construction of the roof, basically, the old flat roof was left in situ, and had a tiled roof built over the top. He's quite surprised that the original construction of the garage roof took the extra weight of the pitched.
Apparently the mini digger is turning up today to pull down the structure of the garage, and break up the floor.
I have a very ecited 2 1/2 year old at home with his mum today..
Hum. That's exactly what I was thinking of doing to the flat roof extension that is my kitchen. Build a wooden frame over it and tile at my leisure without worrying about rain etc. whilst the felt is in good condition.
TBH, the utility roof (the last photo) was done like that, and it didn't seem too bad because the flat roof was supported on top of the walls. The garage was a bigger issue. When it was originally built, it had the flat roof laid on the joists, and the joists were supported by a 2by4 nailed (yes, Nailed!) to the outer wall of the house. Fine, for a flat roof, but the builder was surprised that it hadn't given way when they loaded it with a complete pitched structure, and a couple of tons of Clay Tiles.
Someone was really happy that the digger arrived, so the obligatory photo opportunity..
Those of you who know the trouble I've gone to regarding the 6inch sewer that runs under the proposed garage know the structural engineers and Wessex water designed a re-enforced steel foundation for the garage. This supposedly puts no bearing on a 6 inch pipe that is over 2m (10ft) down..
Here's the re-bar in place for the footings..
For a garage?!?
The builder commented that he built a 3 floor house on foundations like that a while back..
Yeah, the floor is a bit hefty. Unfortunately, there is a sewer 10ft down, under the base, so the water board wouldn't let me build over without structural design.
The only alternative to that sort of slab construction was to dig to below the level of the pipe, and bridge the crossing points from a set distance either side of the intersection. Because of the way the pipe cuts under the slab, that would have meant 3m long lintels on foundations that were (minimum) 11ft down.
Anyone who deals with underground 'stuff' (I'm a trained Appointed Person - Confined Space), will tell you, the H&S implications of going that deep on a small build like this aren't small, let alone with what would effectively have been an unsupported trench. Add to that, the increase in plant size to get a digger needed to dig that deep, and the conclusion was that this, although overly engineered, was going to be the most cost effective solution.
Beginning to make the footprint of the house look rather large..
Had a visit from the garage door people. I'm pretty sold on a roller door, they have a better seal - which is good at the bottom of a slope, and you can park right up to the door and not worry about opening. Also, the rolled up door should pretty much fit right up into the eaves, so I get maximum headroom. Lets see what price they can do, the GTE keyring may soon have another remote fob for the door!
Next week the front wall of the conservatory is coming off, so that the back wall of the garage can be built, and hopefully we'll have lintels and ceiling rafters by the weekend..
Yeah, its really nice to have a builder that turns up, does the work, and doesn't disappear for days on end on other jobs. I suppose it's because he's a small family builder, all the work so far has been done totally by him and his son, and the best thing is he's local (in the next village) which is a plus for me..
That CB cement truck looked brilliant.. I didn't realise that they delivered concrete like that.. Great idea though, turning up and mixing it on site means no wasted loads, and they can mix just the amount you need rather than having 1/2 a truckload left over and dumped..
I'm looking at my options on the floor.. Left it as a standard brushed finish so that I can do what I want when its back in my custody..
Bit of progress made. The roof was taken off of the utility, and the shell of the new bedroom is nearly done.
You can just about make it out behind the scaffolding..
Unfortunately, the conservatory roof fell victim to some thermalite blocks coming off the second floor platform in the recent winds..
The new garage looks deceptively small. Its because the door is most of the width of the space, the garage is actually approx 3.1m (10ft2) , and the door is 2.5m (8ft3)wide.
Apparently all of the roof trusses and timber is due to arrive tomorrow morning, hopefully we should be getting sealed back up by the end of the week..
Yeah, its in the shed.. Shergar is looking after it for me..
Related Threads
Vauxhall Owners Forum
4.7M posts
72.6K members
Since 2000
