1 - 8 of 8 Posts
where does the temp sensor go to? how does it work i.e. get an accurate temperature. Does it read the interior or exterior temp of the engine? I want to try get this temp sensor on the manta working propperly. I'd imagine its te same set up as cavaliers and astras etc
Where to duz it go so I can check the wiring and fix it. I have no idea how it works.
Whats a good temperature of the engine so that I know when it's over heating? I'm fitting a radiator fro ma different car onto it so I want to monitor it's getting enough cooling from the new rad.
I had the same problem with my XE'd Manta, still the same now i have an LET motor in it, I fitted another temp gauge, but problem may be to do with voltage regulator on the back of the dash.
Discussion Starter · #8 ·
only problem with mine is the loom has been changed so much, different wires buttheir is something left of the bumper. kind of like a 4 inch brown rusty lollipop?
1 - 8 of 8 Posts
