right
the only difference between the c20seh and c20ne engine is the cams, pistons, and ecu. correct?
everything else is the same, head, bottom end, manifold etc.
so in theory, if i were to put seh cams pistons and ecu on my ne, it should run c20seh spec (it wont as its down on power anyway).
and could i fit a rebuilt top end (head etc) from a seh to my ne?
gen needed
Yes, but if you got a C20SEH to nick the parts out, you might as well just swap the engine over, you going to be taking it apart and remving it from the car anyway.
