My sister has got a 1.0 12v 51 reg Corsa C.
It seems to have trouble selecting gears, particularly when changing down from 3rd into 2nd. its alot easier if you do it quickly and by blipping the throttle on up change which is the way i tend to drive. But if you try to do it slowly then you some times just cant get it into gear. The clutch seems to be fine, and dosent slip atall.. You cant adjust it because its a hydraulic clutch.
any ideas?
Hydraulic Clutch?
Needs bleeding, or Master/Slave cylinder replacing?
Can i just ask, do you grease up the linkage after? my astra has a brand new one but it was bone dry and changing gear was a bit gritty, so i greased it all up and its perfect.
