right following on from my other thread about the car not starting when hot, so i replaced the crank sensor and it it all seemed fine, but i tested it in the evening when it wasnt so hot, buttoday when i got to work, i turned the car off and tried to start again it wouldnt, anyway got home and it did the same thing, plugged into the lappy and, cranked the engine and got a rpm signal from the crank(cranking at around 250-300rpm), every other signal it working fine, tps is at site 0, cts is reading as is air temp sensor.
one thing i did notce while cranking was the injector duty cycle was spking up to 100%, should this be happening upon cranking?
any ideas?
any ideas?
