Recently bought a Cav GSi which is in need of TLC.
Unfortunately the 2 front electric windows are tempremental! The driver one will go down but is very very reluctant to go back up, have to pull up on the glass while pressing the switch on/off.
Passenger one can be a bit pocky too, but the rears are ok.
Before I remove the doorcards and start fiddling, any suggestions on the cause and cure?
Thanks!
you can buy rubber and vinyl lubricant from halfords, bright yellow tin same kinda size as large wd40, will be with all the other oils and lubricants.
spray that on the felt runners, and wheeeiiiizzz.
Thanks OddBall, I've read this on several of your other posts (after posting this thread). I'm gonna give it a go tomorrow lunchtime, by the way: sure you're not on commission!? ;)
quite good, it worked well on mine and not so well on my mates.
