its an american mp3 player i got in there. only does this when you crank it up or connect more speakers to is (ie all 4 speakers on)benhelen said:what stereo is it and where are your power cables coming from the earth and the ignition and memory power
aint got a clue, was on there when i bought it before xmas....Chameleon said:How healthy is your battery? Is it up to the job? \\\this is wot mine used to do. A nice new Optima sorted that...
so you say i run a earth to an earth point and a perm live to the bat to replace the live from the ignition or somit else ?benhelen said:your speakers might be dragging 2ohms out of your stereo which will be a power drainer you need to double check ALL your wires i allways add a single earth on its own and a perm feed straight from the batt my alpine used to fade then i did the above and no problems my kenwood i have now is wired like that plus i am running five amps and a crossover and it is fine try it![]()
