Hello. I had done swap to c20xe m2.8 at my astra mk2 (kadett gsi)
The right engine mount bolts up.
What have I to do to mount steering pump?
Original steering aluminium mount goes at engine mount holes.
If I put pump with 8v brackets, belt comes off..
PLEASE HELP
If the belt comes off, either it isn't aligned properly (use a ruller's edge, or similar straight thing to check) with the pulley(ies) either offset or twisted, or both, or the belt is the wrong size with it being either too long or the wrong size, or both. Oh, or not properly tightened. That's a LOT of or's.
If you post a couple of pictures of the pulleies, we may be able to narrow it down
The pulleys are aligned. Iron brackets are weak for the multi channel belt. The pump moves.
If I put the aluminum bracket and automatic tensioner the belt does not match well.
