1 - 8 of 8 Posts
Hi James,
If you are using cellulose you should mix it 50/50 (so in other words the same amount thinners as Lacquer)also if you are
going to paint in the cold use anti-bloom thinners it'll give a
better finish.
ROD:)
it all depends on the temperature you are spraying at, standard spray temp is 21 degrees c but you cant acheive this in a garage! anti bloom thinners will eliminate blooming, which is sort of a white pasty clouding effect in the lacquer..........im pissed at this moment in time but im sure its true lmao :beer:
1 - 8 of 8 Posts
