just 1 single rca output on the headunit.Orbital said:do you mean it has one out with 1 red conector and 1 white one
or just one conector for mono?
Orbital said:that's a mono output for a sub then. if you want rear amped stereo speakers you will have to run speaker cable to the amp and use the speaker cable input. if you only want mono at back then there will be a switch on the amp to run mono. just plug the cable in one input if nothing try the other![]()
