Good Morning All,
Desperately trying to find a part number for a shorter XE timing belt as I have deleted the mechanical water pump, and thus the pulley.
The standard XE belt is (I believe for a late model XE): 176 Teeth, 24mm wide, 3mm deep teeth, 8mm pitch.
I require a belt same width, tooth size and pitch, but as close to 152 teeth as possible. I've attempted to make contact with Gates but they never respond.
Any help given would be greatly appreciated!
Discussion Starter · #2 ·
Just to give an idea of what I'm trying to achieve and the amount I'm looking to loose on the belt.
Motor vehicle Automotive tire Automotive lighting Automotive design Automotive exterior
