All,
Someone will know this I hope. 93, 2.0L carlton.
Problem I have is it wont idle, it sounds like it wants to go but just wont fire run. I have replaced Dizzy, arm, leads, coil, & made all the usual checks. No fault code & ECU light goes out after about 5sec anyway.
Getting mad with it now, got good spark & fuel but just will no go.
Someone told me to replace the "crank" sensor, is this the one by the PAS pump? how do you remove & how much are these?
Thanks , hopefully some can shed some light in this.
Regs
Bobby
Discussion Starter #3 (Edited)
Stoneyginger said:
Sounds like your Lambda Sensor mate :) if that goes it will run too rich or just make it not want to run at all :)
Many thanks for the reply, I had already thought about this, but I always thought that if this went then the Eng Mgmt would light would stay on. Or at at least give a code detailing this was at fault?
The car wants to start, its annoying as it sounds very healty when cranking over. I had a similar prob about 10yrs ago on my GTE, that turned out to be the "hal" sensor with in thin Dizzy? the Carlton doesn't have the same setup which throw me.
I am gutted as the car is my friends & without it he is lost, he doesn;t hasve much cash so I was just trying to save him the cost of a Auto Electrician, i think this may be his only option though.
You help is appriciated though, will disconnecting the CO2 sensor enable the car to start? I will try this afternoon, thanks again.
Anyone else have any suggestions
Kind regs
Bobby
right its running.
changed crank sensor and cable & its working BUT...
Its now over fueling very badly, as in black smoke & small flames out the back....
No fault code, any ideas
cheers
Regs
Bobby
