G
I may be able to get a brand new Garret T25 turbo unit from a rover. Will this fit a c20let with the manifold that is available from places like regal and courtenay?? What advantage/disadvantages are there if the turbo would fit??
the chances are the compressor and turbine wheel sizes would be unsuitable for the LET, the T"25 as with the T3 is a general spec turbo there are lot of configurations eg a metro T3 is a lot different to that of an rst turbo.
true observer... but isnt the Rover Turbo a 2.0 engine also?? so the likelyhood of it being a reasonable match would be quite good no???
You can check the A/R ratio of the Garrett turbo - it will be stamped on the housing. And you can compare it to your turbo.
l8r
