when removing the oil cooler from 20xe for nova conversion can i use the filter stud from a 1.2 engine to replace the long one through the sandwich plate. what oil filter should i use with no oil cooler???
BENM said:
are all non oil cooler studs the same then or do i ask for a particular one?
thank you.
Well in Vx I explained the reason why I wanted it and I think it was the part number for the oterh 2.0l blocks, i.e SEH or whatever. That will defo work, but I don't know if ones off other blocks will fit, I had to wait a couple of days for mine as was to order and was indeed 3 quid ish.
Dan
