i've bought a redtop to put in my corsa b ,im not goin to buy a (conversion kit), i think its called cause i dont have £500-£600 to spend :( , can any one tell me what parts i need for the conversion and is it possible to get them all from the scrappy?as i dont have much money to spend.thanks for your help.
corsa gsi driveshafts (22 spline)
cav mk2 1.6 inner cvs
Engine mount kit(drivers mount and gearbox spacer)
corsa 1.0 12v top radiator hose (5 quid from autovaux
ecotec induction elbow and adaptor plate
16v corsa header tank
youll prolly find you have an electomagnetic speedo pickup, so you need to use the original sender from the donor car with cable clocks, or an early corsa electomechanical sender with your clocks.
obviously youll then need brakes, exhaust, suspension etc. Im running a cav turbo cat on mine as I need it for mot and with the bore it shoudlnt be too restrictive (2.5 inches)
